LBZ: Recommended Mods
5LTREATR
Oracle
Apr 10, 2009
46
Winnipeg, Manitoba, Canada
Hey Guys i need help I have an 06 LBZ Duramax with EFI live tune putting down an extra 150rwhp, I have 4" turbo back exhaust, with a cold air intake as well what do you guys recommend for my next mod I am not sure what I should do next.
Alligator
Nov 9, 2006
1,919
N. Idaho
Gauges, ported fuel rail fittings, Diamond Eye down pipe, BD manifold, tie rod sleeves, Cognito Braces all come to mind as well.
maine04max
Dec 11, 2008
1,009
Like I told you in chat call MikeL he will guide you in the right direction on your tranny
9,905
151
Depends on how much money you have to spend.
If money isn't an object, then yeah the built trans is the way to go. If you are on a budget then "I" would go this route in order:
EGT and Boost gauges, shim your fuel pressure relief valve, install a lift pump, install at the very least an Ally Jr. Shift kit in the transmission, get rid of the stock tie rods and go with a set of Cognito's if you ever plan to drag race or pull in 4WD.
Then start looking towards doing a built transmission-whether it be Suncoast or ATS with a new torque converter, and then start saving for pistons and ARP head studs as some of the LBZ's unfortunately like to blow pistons and head gaskets at the higher hp settings-cause your going to be having too much fun to keep the power in check:D
The only reason I say hold off on the fully built trans is because the 6 speeds seem to hold up to the power a little better than the 5 speeds did, but it all depends on the driving style too.
OT but I have lots of family in Winnipeg, maybe if I head that way this summer I will look you up!
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
tranny just cuz on mine my c3s were starting to burn bad with just a stupid ts performace module at the "100" hp setting (at least in my rookie opinon)
on a side note a new coverter and clutches shift and feel stupendous!!!! with courtesy of Mike L
