What do you consider expensive? Expense vs value is a double edged sword to me, I see the frugal value of building your own, to an extent, that's cool if you want to directly weld to your frame and all. I have also seen a set that mounts by cutting a hole in the frame, can't remember if there was welding in that set or not? And all seasons and cognito trac bars are both pretty good, I think all seasons has a stronger set available, both a light and heavy duty set. Also what's the total for a set of bars and stops?
I guess what I'm wondering is what is the purpose(s) your truck fulfills? Even though the set was something like $380, I find great value brought to the table in a set of cal tracs by Calvert. They can be removed easily, they are super easy to use, they are tougher than nails, and adjustable for multiple duties. They work like a champ form1/4mi duty, I have seen guys use them for pulling and doing well with them too. They work two fold as well, both eliminating axle wrap, which helps keep axle hop to a minimum, and also pre loading the spring pack to completely eliminate axle hop and transfer more of the energy to the contact patch of the tire, kinda like solid blocking the spring pack, but better.
Versatility has to be counted for in my book, it has value as past the initial cost
Just a thought
