In the end, the kit was quite complete, but definetly a generic one. I had to buy the following stuff to finish the install:
4' of synflex hose-of which I used all of!
4 - 1/8" NPT collars to install the nozzles in straight into the manifold instead of with the suplied 90's and also to join the hose with the required extra length
$45 worth of gaskets for the intake manifold
4' vacumn hose for the boost pressure sensor
1 - Mini Fuse tap
I still need to make a bracket to mount the solenoids. I am putting them right behind the oil filler to minimize the hose lenth between the solenoid and nozzles, as well as to tuck them away in a nice empty space. My firewall is all tied up with other stuff.
So in the end, a selection of straight and 90* fittings for the nozzles would have been nice, more synflex hose, a little longer USB cable for the display, and if the boost sensor was a pressure transducer instead of a hose, this would have also been nice. The supplied boost hose was too short-an extra 2' would have been nice. Also, I don't know why but a large ATO fuse tap was included and I don't know of any vehicles being built today that use these fuses so I had to buy a mini fuse tap.
So far so good. More to come after some testing.
