Reassembling turbo, heads, etc..Locktite?
Billdog350
Nov 5, 2008
Portland, CT
So I'm almost done with dis assembly on my 03 duramax which is getting new head gaskets, ARP studs and otherwise new gaskets and injectors where needed.
The Red-orange locktite GM used is overkill IMO. Its a PITA to remove esp when you can't heat the fastener to 500deg to release it. I have had to use some pretty crazy breaker bar arrangements to get things apart, esp at the turbo.
When guys have done the turbos, downpipes, up pipes, etc on their Duramaxes, have you put that crazy glue back in there or used a different (weaker) type of locktite or nothing? I REALLY don't want to use more of that stuff if I can avoid it. God forbid I need to take things apart again I'll be SCREWED for sure.:toilet_claw:
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
You're saying you found thread locker on the manifold and uppipe bolts?
Use a small amount of anti-seize on exhaust components, a drop of thread locker on small bolts for the rocker housing and valve covers. I've always used the blue medium strength.
Billdog350
Nov 5, 2008
Portland, CT
I'm saying my manifold to up pipe, up pipe to turbo, downpipe to turbo and several other bolts on the truck esp exhaust related have the Red-Orange Locktite 272 on it. Because I can't heat those parts to 500 deg to release the bolts it has been a PITA to take things apart.
I have ALWAYS used anti-seize on exhaust components in the past but this has totally baffled me. I'm wondering if there is some significant vibration that is different on the duramax that's not on every other gas and diesel motor out there ;)
13,736
805
I don't recall ever seeing any thread locker on any year Duramax up-pipe bolts.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,215
365
At Da Beach
If it was in the exhaust system shouldn't it have been well over 500 degress everytime you drove it. Thus melting and turning said loctite to powder anyway. It was probably just rust and anti sieze.
