Was under the truck this afternoon and noticed a good bit of fluid sprayed under the cab and around the rear seal on the transfer case, which i just replaced . When i grab the output yoke it moves up and down and side to side and i can hear it rattling in the case.
http://www.merchant-automotive.com/263XHDLBZ.aspx
I believe according to this diagram from MA i need B25? (Rear output shaft bearing). Is there anything else that should be replaced while im in there? Already done the pump rub kit... Also what can be done to keep this from happening again? Traction bars?
Sorry for all the questions and thanks for the help!
Alex
Alex
