My guess would be to not take room up in the bed with an aux tank. And it might be cheaper then a titan tank
a friend of mine from Austin does, and they are amazing. He makes them in basically any size you want and put fittings where you want them and what kind you want. On my race truck all i had to remove was the spare tire support but i have seen some other 1500 with a full-size tubular cross-member that has to be removed
P/N # 15825666 $317.20 Plus shipping
That was from gmpartsdirect.com
I dont run in any classes just test and tune but the real races are on the streets of mexicoUm I love what ur doing but nhrda has different thoughts on this
Moving the fuel tank from stock location and battery not in front of the fire wall bumps you to pro street. Just FYI
That's awesome. Any idea what a 30 gal tank with a sump and stock sending unit hole would run me? It'd be going in the same place you've got yours so the dimensions should be similar.
