Rear main seal leak?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I have a mysterious oil leak. I thought it might be the turbo oil drain but I can't seem to get an oil when I reach back there. Drips down the pass side of the bellhousing. Whatchu guys think
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I have a feeling that's what it is. I ordered a new oil drain gasket just to be sure. But if it's a rear main it's not getting fixed
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
You can't see anything is the point. Just wondering if anyone has a had a rear main leak and if it's a similar one to mine
ripmf666
15,123
14
47
Wentzville Mo
Jordan if it was the rear main seal it would stay low on the bell and look like the front pump seal is leaking in the trans, if its up on the side of the bell its coming from the turbo drain of valve cover area.
FMOS
Hard Up
Nov 19, 2008
352
Fort McMurray, Alberta, Canada
I got the same oil leak...
I know for fact that my turbo oil supply line isn't in tight enough and is probably leaking a wee bit. But I have to drain the oil to be able to take that line off and tighten it up. If I recall I need a 21mm deep socket.
I usually have wet residual oil on the bottom of the bellhousing right behind the oil drain plug. Sometimes on the bottom of the trans.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
My feed shouldn't be as it had new crush washers. I had to reuse my oil drain so I'm sure that's it
[email protected]
cmitchell17
Sep 8, 2008
251
If its not, try AT-205 Re Seal you can get it at Car Quest Parts houses. It sealed up the annoying hydroboost leak that every single truck I have seen with one has had.
