Like the title says, my rear door locks are currently not working. Front door locks work fine but using the remote or the lock button on driver door make no difference on the rear locks.
The truck is newer to me so I don't know a lot of it's history but it does look like it had a security system at one point (column was punched and radio missing when I got it, so I replaced both of those).
Here is what I have done so far:
- Tried a new door lock actuator (no V seems to reach the actuator for either back door even though both all relays/fuses are good)
- Can hear both 'Lock' and 'Unlock' relays at the drivers side fuse box. Still swapped with new ones.
- I can remove both relays and the '20A Lock Fuse' and front locks still work (removing the 10A PDM does kill the front locks)
