Rear Diff Disassemble instructions
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
Anyone have any simple steps? I left my manual with my front diff at the mechanic in town so I have no idea on the steps to get my carrier out. Can anyone do it off the top of thier head?
nar
Now with less _
Feb 7, 2008
199
Wyoming
Dunno but I assume pull the axles, pull the bearing caps, pop it out with a bar. I need to look into mine too, G80 isn't doing shit anymore, which really sucks when it's icy out. What are you doing in yours?
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
I would do a write up if I knew what I was doing. I should have my front diff (and GM manual) back tomorrow, I can maybe do a write up this weekend. Maybe it would just be easier to copy the manual? :D
nar
Now with less _
Feb 7, 2008
199
Wyoming
That would be the torsen unit? Does it come with a complete new carrier or reuse the G80 carrier? If it's a new carrier does it come with the bearings pressed on already? I am tempted to take mine apart and just weld the damn gears together for now until I can afford the better locker. I'm not going to be towing heavy until summer anyway. I just get tired of spinning all the time, can't go anywhere in the snow without 4wd hardly.
partsguy662
blowup doll salesman
Aug 14, 2006
377
BMDMAX (Brandon) did a write up on this a while ago if I remember right..He put the torsen set-up that chrysler uses in his as I recall..
On edit:
See this:
Rear end rebuild
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
Yes, its the torsen unit. It has its own carrier, and the bearings were not pressed on. I was gettin tired of leaving one-wheel-wonders too! :D
On edit:
See this:
Rear end rebuild
Yeah, I saw that thread, but I didnt have much for assembly and dis-assembly instructions. Good pictures though. My governor looks just like his did! :eek:
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
Well.......I ran into some "issues" today. First I thought I would just figure out how to do it myself. The Cross pin is held in by a roll pin that looks like I have to come in from the backside of the ring gear to knock it out. I didnt have any roll-pin punches so I went to go get my AAM ready to put in.....the carrier bearings were 1/2" too small on the ID! I panic'd and called the place I took my front diff to to make sure I didnt give them the wrong bearings. They hadnt even started on it yet and they promised it done at the end of the week. :( BUT, the bearings were right for the front. So, I callled ACCU and they couldnt get anything out until Monday. I wont get them until at least Tuesday/Wednesday. Its gonna make my goal to be all done by next weekend hard to meet! I did grab my manual so I can get my G80 apart though. I'm heading out to the shop for an hour or so now, I'll let you know what I find out.
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
Wow, it was a lot simpler than what I was trying to do. I thought I had to take the center out of the carrier to get to some axle clips....Wrong. All I had to do was take the 8(?) bolts off that hold the axle to the hub and then the axles pull right out. I used a punch and some light tapping to back off the bearing adjusters after I took the caps off and it fell right out. Now I just need the right bearings. I was going to take pics and do a write up, but thought the pics would look better after I do Maxlly's rotor mod. :D I 'll take pics on re-assembly.
