real world mileage and problems
BigLou80
Oct 7, 2016
3
So it's been a good year and I am about to pull the trigger and get one the last of the 2016 LML's. I know the L5P has some impressive numbers but I'm leary of owning the first of a new engine series and it's $5,000 more. I was hoping to get some real world feed back on the LML in our variable climate.
What have other people in the north east experienced for real world mileage and problems? I average 100 miles a day 75 of which are highway but doing 200 a day isn't unheard of. I frequently tow a 6500 enclosed trailer and will occasionally tow a 14,000 lb dump but I am not worried about the mileage while towing that. My LB7 seems to average around 16.5 -17.5 MPG with my habits
Thanks
Dozerboy
4,892
470
TX of course
Does buying a new truck hinge on the mileage for you? I just ask because that's a pretty subjective question.
I would expect a lml to get worse then a lb7 and better then a lmm.
roxyfever
Feb 11, 2016
191
terrell tx
Also mileage will be lower till you get some miles on the new truck. 18-21 hwy an 15-18 city if I had to guess. Lots of variables to that
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
empty i was around 18-19 hwy. towing mine was horrible till deleted. depends on how heavy i was pulling. worst i saw was 8.5-9mpg with my s250s or excavator on trailer 12k-15k. best i saw pulling my ranger 620 was 11.5mpg around 5-5500lbs. that was completely stock. and has around 13k now.
now it should get better as i get some more miles on it like all my trucks have.
now deleted running the 150hp tune pulling my boat i get around 13.5-15mpg. empty hasnt really changed much. 19-20 is best ive done so far.
pulling my s250s or excavators i get around 11ish now. on the heavy towing tune. no idea on hp.
i have,
5in turbo back
mbrp down pipe
moonshine tunes.
air dog 165 4g
s and b intake
pcv re route
resonator delete
7in lift turned down to around 5.5in and 35s.
mebob2001
Riverview, new brunswick
i have,
5in turbo back
mbrp down pipe
moonshine tunes.
air dog 165 4g
s and b intake
pcv re route
resonator delete
Is the 150 horse tune a towing tune? Or a playing tune?
Sent from my SGH-I337M using Tapatalk
arneson
Aug 14, 2011
2,133
tony calls the 150 tune a "race" tune. i bought 5 tunes.
i got the heavy towing, 100hp. 150hp, 175hp, and 245hp.
i havnt pulled anything on the 150hp heavier then my ranger. and im not going to till i get my trans done really soon.
anything around 75-100hp you should be able to pull what you want within reason. you can wreck a stock truck with the wrong person driving it.
Sent from my SM-G925V using Tapatalk
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
i have,
5in turbo back
mbrp down pipe
moonshine tunes.
air dog 165 4g
s and b intake
pcv re route
resonator delete
Hand calculated or dic?
arneson
Aug 14, 2011
2,133
everyone always says these trucks get so great mpgs. but i sure havnt had it yet. granted mines lifted, so i dont care all that much. but my lbz on average did 2mpg better in any aspect. pulling or empty. but the lbz wasnt stock either. twin turbos, injectors, built trans ect.
BigLou80
Oct 7, 2016
3
It matters but it's not the be all end all, accounts receivable and bank financing are. While I have hit close to 19 MPG on my LB7 my last calc was 11.9 towing my 5,000 LB camper down hill at 65MPH, I got 12.9 towing it up hill to get there.... I'm just sick of throwing parts at my LB7 for it's lack luster performance.
S Phinney
4,008
Quncy, Fl
if i drive any city with mine i drop to 15-16mpg. the 19mpg i was talking way highway driving.
All if your fuel data sounds right on par with what I see as well. Of course I probably run a little more hp tune than you are running most of the time.
S Phinney
4,008
Quncy, Fl
what tunes do you run most the time?
stock trans or built? do you pull with the higher hp tunes?
I do my own tuning. I do sell tuning as well. I can tow on higher hp tunes without issue as long as you watch your temps and drive appropriately. I do have a built tranny. On the stock tranny I would not recommend what I currently run because it wouldn't last if you drive very aggressively. I like a responsive truck.
Troysalm71
286
Bemidji, MN
Do you run ridge runner tunes? I've been running korys runs great. Your numbers for hp on the big tune are more then mine anyway. My truck I just leaves turned up unless i pull. It has done 19-20 the dic always says like 22-23 or somthing though.
Troysalm71
286
Bemidji, MN
Little off topic are those numbers based off cp4 tuning? If so maybe I could squeeze more having my fleece stroker pump.
arneson
Aug 14, 2011
2,133
i couldnt tell you forsure on hp. im just going off what he has listed and titles them as. i did have another denali i worked on for a guy. his had korys tunes. smoked alot more then mine and i was a touch faster. only info i can give. both seemed very nice as far as tunes go. id run either one.
mebob2001
Honestly these truck pull great deleted in stock tuning. I don't see why ya need the 150 horse. Plus the timing involved with 150 is just asking for bottem issues imo.
That's alot of extra stress on rotating assembly. Hell in race tune on my lbz I see 23 deg advanced in higher rpms and I hate it. But it's fun ya pay to play:)
Daily I use optimized stock. Usally stock when towing unless I can't get up the grade with 14k behind me. Throw heavy tow on and she charges up no problem
arneson
Aug 14, 2011
2,133
yeah my last personal truck was a lbz. it had twins, full built trans, injectors, dual pumps, and lots of other stuff 685hp+. i cant drive a stock hp truck. i hate it. all my vehicles i own for my business, not 1 of them are stock anymore.
always get alittle bump in fuel mileage in most cases as well. which is why i also like above stock.
so i hope that answers why you cant understand why i need a 150. i dont ever have anything stock. :)
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
23° on a race tune? Sounds more like a healthy tow tune
