hey guys i have been running the current tune for atleast 5 months and about 3 months ago i made it my main dsp tune. it has been fine, but now with the warmer weather i have a couple issues. first it seems there is no feathering the throttle. taking off from a light seems to be a chore to take off smooth and not like i am racing. it is the biggest issue i am having, i cant seem to figure it out. i have tried adjusting the tbiq table and it made it seem like the throttle would just come on the same but a second later. so i put it back to where it was. then i compared the stock tbiq to mine and mine is actually lower or smoother when in that rpm range. not sure what else to try. i have a milage tune in my dsp and i have to switch it to that when trying to back up any incline or my driveway because the throttle is so sensetive it just barks the tires. my milage tune does not do this and it has a stock tbiq table, and mostly stock pulse table. any thoughts on what to look into???
my second issue is less concerning but something that jumped out at me replaying the logs. when coasting down 0% throttle say off an exit ramp, then sitting at a light it is commanding 15-20mm3 and it makes my pulse table looks like a landrover proving grounds. up/down/up/down. i range from 500-1000 us at idle. you guys see the same???
