Re coating frame
lutzjk913
1,691
185
groveport, ohio
Looking to pull the bed and start re coating the frame soon
What's everyone using to do so and what steps?
I remember seeing somewhere on here a while back where someone did it but just spent the last 30 mins looking and can't find it.
Thanks guys
Yngdmax92
962
There was a whole thread about it, but guys have had really good success with oven cleaner.
I am interested in different kinds of under coating besides POR15. Stuff is good but id like to here about others
lutzjk913
1,691
185
groveport, ohio
I can't find it. I tried searching and gave up.
I've seen people use KBS before and it turned out well.
I'm hoping someone can recall which one I'm taking about.
wilrob
Back in the Motherland
Sep 14, 2016
366
Dallas, TX
Thanks guys
pressure wash, scuffing pad/ wire wheel on the places, rustoleum. My frame is pretty pristine though
melms23
253
WI
I don't get too carried away. Power wash and blow all the hard to get to spots with air compressor. rustoleum black and then rubberized undercoating.
I spray the undercoating again with black paint because it fades in spots that are always in the sun. If you keep up on it it works well without too much hassle and cost effective.
lutzjk913
1,691
185
groveport, ohio
Ok. Thanks.
Ok. Cool. Hoping to do this and it be good for some time. Would it to last and look good.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
How bad is the frame?
If you don't remove every inch of previous undercoating, Por15 / Chassis saver, etc will peel up around the edges. Surface prep needs to be 100% for a rust proofing coating like those.
If you're just pressure washing and doing basic de scaling, I'd hit it with some high zinc primer then JD blitz black.
lutzjk913
1,691
185
groveport, ohio
Back half is bad imo.
Planning on trying to get to bare metal and go from here.
KBS offers a 3 step process on it.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
If you go that direction, the kbs kits are fairly cheap.
I'm a Por15 user for life, no reason to switch. BUT I'm sure these other companies know what they're doing :thumb:
