RDL Profab manifolds ports off center??
Swisstyphoon
258
Ft. Lauderdale FL/Switzerland
Im about to install the RDL manifolds and up pipes, I just noticed some of the ports are off center. The gasket matched the head, the cut out in the gasket is longer but the hight matched exactly the ports on the head. If I lay the gasket on the manifolds now, I can tell some of the ports are off center.
Anyone noticed the same thing?
Looks like I have to port the manifolds with a grinder...
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
I had to gasket match a set also. I used some new bur bits and a right angle drill. The low speed will keep the shavings from flying all over you. Worked good and took me about 3 hours for both. I finished with a Milwaukee die grinder and a flapper wheel.
The set I did was not off as much as yours. The ports just needed to be opened up side to side.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
you'll always get inconsistencies with heads and headers / manifolds. the trimming your doing is an old racing trick called port matching.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
The ATS manifolds i had were perfect even after i got my heads ported i couldnt use them due to running the stock down pipe so i sold them and bought the rdl cast flows and had to port match them as they were undersized for my porting.
Kutchey2
Apr 15, 2011
122
I'm pretty sure the port size of the heads is smaller than the gasket opening. The manifolds were probably designed to match the stock heads.
c55asleep
Apr 23, 2009
163
Miami,Fl
Ive bought many sets of headers (manifolds) and have never had this issue. Only one set of headers gave me problems to install and that was due to shipping error.
Rolf, at least you got it taken care of... Do you have a pic of the manifold itself????
D-MAX Mafia
Nov 4, 2009
1,112
13
Phoenix
The new PPE manifolds match up perfectly! All I did was polish the runners with 80 grit flapper wheels on a die grinder.
RickDLance
1,276
14
I've never heard of this before. I'll be more than happy to replace them for you. PM me your info.
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
i was thinking the same thing about the price, glad to see Rick stand up and back his product. Never heard anything negative about him or his product.
jewelaudio
Apr 16, 2012
35
Morris, IL
:thumb: Thats awesome...you never know who is reading these posts. Manifolds are in my future plans as Im sure they are in others reading. I went from remember not to buy...to wow great service! Put those at the top of my list.
