LBZ: Rattle when block heater is plugged in
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
Haven't used the block heater since last winter and don't usually use it as my truck is parked in a garage. Plugged in at my friends tonight and heard a rattling noise. Sounds like the thermostat opening and closing and it's never made the noise before. It stops momentarily if I squeeze the top rad hose. Does this seem normal?
3,732
302
Mine does it too. I don't think anything is wrong. I believe it is the little air purge tab rattling up and down due to very low coolant flow (convection only).
You don't hear it when the engine is running because:
  1. The rate of coolant flow is much higher, forcing the tab full up.
  2. The engine is way louder than the tiny rattle noise.
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
That makes sense. I just went and checked and it quit doing it now. Maybe it was making noise like it was due to the coolant still being warm. :dontknow:
Guns and Grease
Apr 12, 2011
11
Northern WI.
My block heater started make this weird noise a couple of months ago, it never has before, so I was a little concerned. Well, about 2 weeks later the block heater quit working. I replaced it an the new one doesn't make the rattle/humming noise. But seeing as this thread is over 2 years old... everyone has probably figured that out by now.
