Rail pressure
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
What are the advantages/disadvantages to raising rail pressure while tuning. I know some tunes/boxes raise rail psi and some don't, I was just curious as to why.
I know more consistent psi at wot, but is there anything else i.e. better fuel atomization, noticable power difference?
Any disadvantages, i.e injector (LB7 especially) or cp3 wear?
I tried a search, but nothing came up.
racinmike77
Sep 14, 2008
1,029
MD
more pressure will allow more fuel to be injected with the same pulse width. Give brayden or mark broviak a call, aparently they have been sustaining 29000 psi in their trucks.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Better atomization will occur. You will get more fuel at the same pulse width if the pressure is increased. With that being said you could lower your pulse width while commanding more pressure to get the same amount of fuel I belive.
super diesel
<<<< Under Pressure
Steve has it right. Don't bring pressure in to fast or you'll have a fuel pressure knock (I did anyway). This is how the original pressure boxes worked (PPE Duramaxamizer, VanAaken, DB Dynomite box). This is where the Duramaxamizer Tony (GMC_2002_Dmax) has for sale in the "Garage Sale" area is welcome (hand control for when you want the pressure). Think it's for an LB7 though. I brought it back up. What a steal.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
As far as injectors with a stock CP3 you aren't gonna get the pressure you need to hurt them. There is a very noticable power difference if you are getting more rail pressure - but just because you demand it doesn't mean your CP3 will be able to supply it.
650
i made a thread about this back in early 07 on diesel place..
in stock setting 23,000 doesnt come until 85% or better TPS is commanded,
curising is ~13-17000 psi pending load... stock
what i did what ramped rail pressure 23k form 1400rpm and 20% throttle on out. i noticed increased responsiveness to throttle in put as well 1-2mpg increase pending drining habite. egts went down 50-100* as well..
also had to re-addjust the pulse width tables as well... mainly they were setup for 1/2 the rail pressuire they were geting and timing tables... need to be adjusted... mainly pulling timing in areas... due to the fuel gettign in there faster
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
remeber that the PW commanded is different than the PW at the end of the shot:)
Commanding a cp3 to full amount (WFO) will do this for short periods
its not a secret:D
