Radio won't shut off when you open the drivers door....
CrewCabMax
Double XL
Apr 23, 2007
66
Ohio
As the title says. But if I open any other door, it shuts off like it should. Also, my door chime dings and dings as soon as I shut off the truck with the key in or out of the ignition. I could roll the key forward and back again and it stops. Makes the noise like the headlights are left on with the door open. But it's closed. Also, my lights don't come on inside the truck 50% of the time when I open my drivers door. BCM need re-flashed? Is there a module that controls this?? Relay?? TIA!!
Trotorx2
699
71
Beaumont, Texas
I'm having just about the same thing going on with my truck. I was thinking it had to do with the switch in my extended cab door. Sorry I don't have an answer for you. I'll be watching this thread.
13,716
779
My truck does it sometimes too. I think it is the door latch mechanism since that is what tells the truck the door is open. I can play with it, and it will start working right.
BlkMax
743
Wasilla, AK
I had an issue with the dome lights not turning off on one of the rear doors on my CC. Cost me $500.00 to fix the problem. :mad::mad: The BCM was haywire, and I had to have the dealer do the install because of the reprogram required with the Tech II.
In my case it was NOT the door latch assembly, it was in the BCM.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Thats it. Mine does it occasionally. I usually push up on the latch mechanism on the edge of the door when it happens, and everything work like it should. It get sticky, using a spray lube (wd40) will work for a bit but itll eventually get sticky again.
