Radiator Washers
andy-stevenson
Jul 7, 2013
838
Bought a Fleece transmission line kit and it came missing the 2 concave washers for the fittings at the radiator. Just wondering if I can just reuse the ones currently installed? They should be the correct size right?
andy-stevenson
Jul 7, 2013
838
I got the stock washer off. Are you running the Fleece lines? The stock washers appear too big for the Fleece fittings...
andy-stevenson
Jul 7, 2013
838
What purpose do the washers serve? Do they just hold the cooler stable inside the radiator? Would there be a problem if I just used the fittings on their own?
Burn Down
Sep 14, 2008
7,092
Boise Idaho
The washer is what holds tension on the cooler/seals. I'm pretty sure it will leak coolant without the washers. Did you call Fleece for replacements?
andy-stevenson
Jul 7, 2013
838
Yes I did. Still haven't received them yet (one of the perks living in Canada) and the trucks down until I get them. Timing couldn't have worked out better though, 5 minute walk from my house to the job site.
