radiator clogged!
REDHOSS02
hard n heavy
Jan 14, 2009
280
F U im from TEXAS
could mixing the green and orange coolant gel up inside the radiator and cause it to not circulate? i have always ran green 50/50 because thats what was in it from the factory. after the 2nd headgasket job the "mechanic" put in the orange! i took the truck back to him and told him it was overheating and he says he pulled the radiator and it is 3/4 clogged! help guys!
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
nobody put bars leak in it right? I've heard of a reaction of the two, but not clogging. see if you can send it out to a radiator shop to get flushed. and 50/50 green is not factory, DEXCOOL is.
REDHOSS02
hard n heavy
Jan 14, 2009
280
F U im from TEXAS
i know when i got mine it was green! thats all i remember. i did put some of those gm stop leak tablets in there but that was before the first rebuild.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
GM hasn't used green since the mid to late 90's. Dexcool is more forgiving on aluminum. should even say Dexcool on bottle or cap somewhere.
jason86
Marv
Dec 30, 2008
78
Sacramento, CA
if im not mistaken when mixed they will form a gel that will clog lots of things. i would do a cooling system flush to make sure that it is all out.
Killerbee
Got Honey?
Don't mix coolant types, regardless of label statements. The organic acid chemistry is not compatable with high silicated formulas (old green), and will usually result in a heavy precipitate. Not very friendly to you water pump either.
If your radiator has the problem, your motor does as well. I would flush well, and even consider using a degreaser.
