Race truck pics
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
FINALLY got the black truck up and going again , we were hoping to have it down to St Goerge for the H&S event but missed it by around 10 hours :( , but we will have it out to the track in 2 weeks for weekend on the edge ! took it for a spin Saturday and she is def going to be fast , 1200 usec tune for break in and it broke the back tires loose at will :D
build details
65 LPM 9 hole injectors by II
2 120% stroker pumps by II
Corillo Rods
Arias fordged pistons
stage 2 cam
stage 2 ported heads with screw in cups
ATI damper
stock flex plate
Girdle / Main studs
ARP standard head studs
2 165 GPH lift pumps
2 stage NOS system
Turbo's are by Comp turbo , ceramic ball bearing , and all 3 are billet
TrentNell
Jul 7, 2008
7,543
slc tuah
Damn, that thing is SEXY.
What size are the turbos?
:secret::roflmao: , i will say we scaled back some of our ambition to just slightly larger than our proven kits , we are still in testing with this brand turbo , so far i really like what they offer for the $$ , they are in the same price range we have been paying for BATMO stuff , and they are ball bearing !
DURAMXD
BOB SAGET!
Apr 24, 2012
348
Wichita, KS
I figured I would get an answer like that. :thumb:
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Thanks Ben , for now i am going to stick with the LB7 stuff , if i had a 03/04 truck i might consider it , but on 01 to stay LB7 was the easy route .
Next time you come across an LLY ECM/harness/injectors/heads/fuel system, hang onto it. Im not sure if you saw my posts a couple weeks ago about how I discovered that an LLY ECM/FICM will communicate properly with an 01-02 body and 01-02 instrument cluster. And also, that to wire in an LLY engine/ECM harness into an 01-02 fuse box and bulkhead connectors, there is only a minimal amount of wires that have to be moved. You dont even have to cut and splice; the pins are the same so you just have to move some pins around.
Although for a truck that is race-only and isnt going to see a lot of miles (and therefore be driven long enough to get to LB7 injectors' failure), probably not worth the cost....
