R&R rods pictures
cntry125
Gearhead
Sep 7, 2008
103
Wisconsin
Does anyone have any pictures of R&R rods from before they were installed? I supposedly found a set Semi-local and just want to make sure that everything is on the up and up. Thanks
cntry125
Gearhead
Sep 7, 2008
103
Wisconsin
Thats actually the same pictures i received. I just wanted to make sure they were legit not coming from a trusted vendor.
9,903
149
$1700 isn't a terrible price. What's the skinny on them? Junk or what?
Sent from my D5803 using Tapatalk
LtEng5
74
CT
was hoping they would be less than Carrillo's. NOT!!!!!!!!!!! per Wagler site $2,650 for a set. Was hoping for a mid-range rod, better than stock, just not full competition. Carrillo's are of a H-beam design and can take a SHIT LOAD of power. These are of the I-beam design, which leads me to think that the power rating would be/is less. and for not that much less than a set of Carrillo's.
65
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
65
False. Howard rods are i beam and are just as good if not better then Cariyllos.
bcdeutsch731
619
13
41
Illinois
Wagler bought the R&R steel rod division and moved all the machine and some of the workers over to his location in Odon, IN.
Wagler only uses these rods in all his builds. Some of witch have dyno'ed close to 2000HP. I'm running these rods in my new engine that should dyno around 1700Hp maybe more :lildevil:
I've seen what goes into making these rod and saw how precise they are. They are worth every penny.
Verlon at ATP
Mar 19, 2015
165
I have had R&R in my truck since 2011. Almost 80k miles on them. I am now putting them in my lly. They will handle 1000hp all day long.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
R&R Duramax rods are just as good, if not better then anything else available today.
Carillo rods are not what they once were either.... They are now made overseas and if your planning on making big power you need to make sure you get the ones that have the better bolts.....
I'm not trying to say there is anything necessarily wrong with the carillo rod. But they certainly aren't superior to the R&R rod.
1,866
65
Brian Crower or Manley is what you are looking for then....
Remember the recent Chinese rods that look sort of like Carillos? If you are correct, could they be from the same place?
The Kansan
Aug 30, 2013
179
Topeka, KS
X2
I was ordering some stuff from wagler the other day for my build and the gentleman i talked too said they have run them in 1900+ hp builds so i thought they would be plenty of rod for my lil 900 horse build. Jeeez 1000 hp used to sound like alot but its not these days. lol .And on another note the guys at wagler are absoutley GREAT to deal with. They didnt mind talking to me about cam grinds for a while on the phone and what would fit my needs best for spray/no spray ported vs non ported heads. They are top notch!!
