Quick question!
chrisuns
283
San Antonio, TX
Does anyone know if you can log the 6-speed via EFI Live or Tech II and tell if a transgo-jr. has already been installed? Or am a left to pull the valve body and visually confirm?
15,681
No. The only way you could tell is if you tapped into the C3 with a pressure gauge and see.
Dozerboy
4,892
470
TX of course
Probably not real accurate but log slip. Even with the stock tune I saw a bit more slip before I added the Transgo. My truck wasn't tuned much before the trango and it was only a small tune. Not more then a 1900us and timing tune for sure.
I can see if I still have those logs, but from memory at WOT I would seen some slip up to 200 before and after it was only 6. That was in 3rd gear and up so the converter should of been locked.
