If you use your base tune as the "hot" tune keep in mind that you will be limited to what you can do with the dsp files
Actually, thats not true. You will be most limited if you set your base to the smallest. Because dsp folders don't have as many tables and they resort to the limiting tables in the base non dsp tune.
Wow....
Low or High HP as your base tune should theoretically be irrelevant on limitations since you will tune your base tune based on needs either way. Each DSP position will only change a certain # of tables and if you want a "HOT" tune then you will make changes to your base tune required for your HOT tune irrelevant if it's your base tune or not.
