LBZ: Questions on twins
BHoward6.6
West Coast
Feb 9, 2011
274
Huntington Beach, CA
I installed a S475 over a GT4094VA.
My boost at WOT is about 40 till the TC locks, then it goes to about 50.
The S475 boost is 15~20.
Other mods.
ARP Headstuds.
ARP Rocker arm Shaft bolts.
RDL's EGR Delete pipe.
3" IC Tube.
PPE billet fuel pick up.
AIRDOG 2 DF-165.
MBRP XP Series 5 in. Exhaust.
RDL CastFlow Manifolds & PPE Up pipes.
Blankets on up-pipes.
Mike L trans.
Do these #'s sound about right?
I will have my drive press gauge hooked up Fri., With twins what is the norm drive press?
Any tunning tips or tricks?
BOV's?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
That 475 is gonna be in its sweet spot around 32psi. Loosen up on your wastegate and let the 475 do some more work. It can also be in the tuning with the gt40 being a vvt.
cafryer
May 5, 2011
1,074
Utah
I dont know on the lbz but with stock fueling it seems about right to me. Put more fuel to it and you will drive them harder and you will see more psi.
Harbin_22
3,858
Southern Indiana
I get about 58# boost to 75# drive. That is a stock turbo with a 475. That is convertor locked and 4th gear and up. I am seeing around 20-25# on the 475 depending on rpm.
