Howdy Duramax residents! After a ton of research, I have come to realize the missing information required to plan my build requires experience to answer so I came here to find some wisdom. I'm looking to extend the life of a 05 LLY and hit 400- ̶4̶5̶0̶H̶P̶ RWHP. I know a tuner can give the HP easily but I also want a healthy truck.
Here's my list, thank you for any help you can provide. I realize some of this is likely situational but any input will shed some light for a guy in the dark.
Is deleting the cat and muff from the stock exhaust worth the trouble?
What effect will a downpipe upgrade have if I retain stock (or gutted stock) exhaust?
What effect will a downpipe upgrade have if I upgrade the exhaust?
Is there any reason to upgrade exhaust without upgrading the downpipe?
How would a downpipe change the tone of the exhaust/turbo?
Is a bigger downpipe useless without bigger up pipes?
If I use a tuner to disengage the EGR are there any physical changes needed to reap the benefits?
Are there any weight reduction mods?
That's enough to get us started. Thank you.
