Questions after fleece tapshifter install
03spoolindmax
Nov 9, 2011
674
Mi
I'm installing a fleece tapshifter right now. Was wondering if you have to drill a hole threw the firewall to run the wiring or is there a factory location you can slip it threw?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I usually feed everything through the big 2" rubber grommet to the right of the brake booster.
You could also find a flat spot to drill a hole and put in a grommet to keep the wires from slicing on the cut firewall if theres not enough room.
03spoolindmax
Nov 9, 2011
674
Mi
Thanks. I already have enough holes drilled in the firewall so I was trying to avoid that. Ill try and run it threw that grommet
03spoolindmax
Nov 9, 2011
674
Mi
Got everything hooked up. It was a PITA to get it threw that grommet but I got it done. Works great. Thanks for the help
03spoolindmax
Nov 9, 2011
674
Mi
Yeah it's pretty nice. Haven't played with it much yet. Just got to work but ill mess around with it once I get a chance.
03spoolindmax
Nov 9, 2011
674
Mi
I ordered it threw suncoast. I only ordered it because of the free tie rod sleeves. I don't need them but figured I could sell them to someone I know. So in the end I'd pay less for the tapshifter.
