LB7: Question
Dirtymx
Sep 29, 2016
Hi I have an 04 lb7 Chevy duramax and I have a stage 4 tune from ppe and when I bought it and installed the tune it had a lot of power and moved quick off the line and now I had to replace the alternator and the belt and now it seems like it doesn't have the power and doesn't seem to get off the line quick is there anything I can check to get all the power back I had from the stage 4 tune
Awenta
4,090
CT
Put the old alternator back in
Seriously how about details. Check the wiring by the alternator bracket.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Did you forget to plug the mass air flow sensor back in??
Dirtymx
Sep 29, 2016
More info on it the old alternator was a 100 amp and the new one is. 145 I have put diesel additive into and it helped a little but not a lot so what can I do what other info would you like
djforrest119
Oct 7, 2013
13
Port Aransas TX
A new alternator isn't going to drag the engine down. Not to insult your intelligence but you DEFINITELY plugged the MAF back in? Didn't remove the passenger side intercooler line or unplug the MAP sensor for some reason? It didn't "lose" the tune
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
If you UN PLUGED the MAF, make sure it's plugged back in tight. If you removed the MAF for some reason, make sure you put it back in the correct direction.., they are directional!
