Short run down explaining my question:
Before installing the dsp5 I had a 'low boost at highway cruising speed' tune
I had the boost set below 1 at 70mph. I could load that tune and run the Banks 6 gun at any level. At 70 mph my boost would be below 1psi
So now on my 'low boost at 70' tune on the dsp5 the boost is NOT changing. I can feel the tune when I switch to it from other changes. But the boost isn't where I'm putting it.
Here's the basics:
Tune 1 - my basically stock, only lowered idle and open vanes at idle.
Works fine
Tune 2- stock vane position at idle - works fine when engine is cold. Vanes open when engine is warm. I'm assuming that's normal tho?
Tune 3 - turbo brake - works fine
Tune 4 - no changes from 1 yet. Any ideas?
Tune 5 - low boost at about 60-70 mph, minor changes to pedal vs tq, and fuel.
I see that each dsp tune only changes the egr off boost and vanes, could the finger stick be interferring with the boost being where I want it? Taking the stick off has been on my to do list....
Or should I change it around and put the low boost tune on 1?
Anything else I should look at?
Thanks!!
Here's the basics:
Works fine
Thanks!!
