Oh now those are affordable! That's probably the route I'll take, since efi doesn't want to "waste their time" with the old stuff...
I wasn't too thrilled with the response on the efi forum..
We never said it was a waste of time, what we said to you was...
LLY calibrations were last updated in October 2008, almost 8 years ago. The amount of time our developer would need to spend to get back up to speed on that controller, then see if the calibrations existed, followed by internal testing and beta testing to ensure the calibrations continued to operate correctly would make the task not viable for 2 requests in 8 years, sorry.
Well its easily a DOZEN OR MORE HOURS' worth of work to go back through the ECM code and figure out the tach signal stuff. To satisfy the needs of TWO people for an 8 year old platform? And you expect all that for free? Come on...
Do YOU want to pay them for their time to figure it out? Guarantee it would cost you a helluva lot more than an "expensive" signal box.
Ben
The development is the 'easy' part of the equation. Looking and adding the code takes the least amount of time. I'd estimate 10-15 hours for this task, then another 5 hours to import that data across all operating systems.
The biggest time consumer is the internal checking that every operating system continues to operate in the same fashion that it did before it was edited. We'd expect that we'd need to spend between 5-7 hours per operating system in internal checking, and then once released another 5-10 hours with adhoc support queries for the changes made.
So that would be 20 development hours, 30 checking hours, and another 5 development support hours.
You tell me if a minimum of 50 development hours for a programmer is an efficient use of time for a platform that hasn't been modified in 8 years with only 2 customer requests?
To assist customers in platforms where additional parameters need to be added where it's not viable for us to do so, EFILive added the ability for users to add these. This obviously requires very detailed knowledge, but the function exists.
If you don't have the skills to add it, perhaps you can find a programmer than can for less than cost of the device ($40) THEFERMANATOR linked you to.
Cheers
Cindy
