TYPICAL PROPERTIES
SAE Grade
15W-40
Viscosity @ 100C, Cst (ASTM D-445)
14.00-16.00
Cold Cranking Viscosity @ -20C, cP (ASTM D-5293)
6,000
Mini Rotary Viscosity – TP 1 @ -25C, cP (ASTM D-4684)
24,000
High Temperature High Shear Viscosity, cP @ 150C (ASTM D-4683)
4.08
Viscosity Index (ASTM D-2270)
140
Flash Point F/C (ASTM D-92)
442/227.78
Fire Point F/C (ASTM D-92)
485/251.67
Stable Pour Point F/C (FTM 7916 Method 203)
<-41/<-42
Scanning Brookfield Gelation Index @ -26F/-32C
4.5
Volatility % loss @700F (ASTM D-2887)
7.3%
NOACK Volatility (ASTM D-5800)
% Evaporation Loss @ 250C
13.37
Sulfated Ash Content % weight (ASTM D-874)
1.5%
Total Base Number (ASTM D-2896)
12
Shear Stability % Viscosity Loss 90 Passes (ASTM D-7109)
9.9%
Foam Test (ASTM D-892)
Sequence I
0/0
Sequence II
0/0
Sequence III
0/0
High Temperature Foam Test (ASTM D6082 Option A)
0/0
Cummins Bench Corrosion Test
Copper increase, ppm
Lead increase, ppm
57
Tin increase, ppm
<1
Copper Strip Corrosion (ASTM D-130)
1a
Continued on Next Page
TD-151
Page 5
Typical Properties Continued
MHT-4 TEOST (ASTM D- 6335)
Deposit Weight, mg
27.1
Engine Rusting Ball and Rust Test (ASTM D-6557)
Average Gray Value
133
Sequence IIIF
% Viscosity Increase @ 40C
35%
