Mike, you said in another thread that you "Build in protection" for the non-defueled shifts, such as those from a PPE programmer with defuel turned off. The way the Tie-up "problem" was explained to me is that as the torque increases, the TCM speeds up the shift, until you get to a point where it tries to shift so fast, you end up in two gears at once and boom: tie up. So, my question is: How can you build protection into the hard parts from the TCM's programming? The only way I could see to protect the transmission from the TCM's programming would be to reprogram the TCM to not allow the shifts to get fast enough for a tie-up.
