Is this the stock trans that came in my truck? And how can I tell if its been "built"?
01 lb7 2500hd 4x4
01 lb7 2500hd 4x4
Looks like it was made in August 2001...does that correlate to the manufacture date of the truck, your sig says its an 01 also, so it seems fair to "assume" it could be the original trans, but that's not a guarantee
As far as I know, there is no externally visible way to discern if the transmission has been "built" the best way to figure it out without tearing it apart would be to data log it and see what kind of line pressure it puts out, also, what temps does it run? Built transmissions have a tendency to run a little warmer than a stock trans, how is your truck put together? Most people don't build the trans for no good reason, if the truck has a bunch of aftermarket stuff and efi live and a bunch more power than stock, you just may have a built trans.
Otherwise, I doubt it.
And also I'd say my trans runs about 195f
that's nothing in texas or should i say normal for most trucks built or stock.there is no real way of knowing without getting inside except putting a big tune in it and seeing if you have to limp home. Not recommended!
I mean sure you could see if the tc is a different color ,if it is what does it tell you other then it might have been changed still doesn't tell you what has been done internally!
I bought this truck as is and I'm still finding stuff that has been done it.
It had an external fuel tank , trailer brake kit, and lord knows what else but most of it has been removed. It has also been programmed, it seems to me the truck was mainly used for pulling heavy loads a lot. I wish I could get ahold of the guy that did all the stuff but I bought it from my brother in law and he bought it from a dealership so I don't know how to find out who used to own it. and this is the first diesel I've owned and I'm only 22 years old so I've got a lot of learning to do.
the best way to figure it out without tearing it apart would be to data log it and see what kind of line pressure it puts out.
I musta missed that PID on the scan tool section file....
Is there even a sensor for that? Now that I think about it I believe there is a port on the trans to plug a pressure sensor into but idk if there is any pressure sensors that relay info back to the ECM.
