Upcoming in a build, I read about doing mikes pressure regulator spring instead of shimming the regulator.
Seems pretty straight forward...instead of adding a shim just swap springs correct?
And for the converter flow valve, I know the transgo kit comes with the new valve, plug ball and spring. Now the hype of grinding a groove/flat on the end of the valve seems to be better for no converter knock down. The truck is only a daily driver at 500hp and nothing more. Is it necessary to have the stock valve modified for no knockdown or will it create a harsh lock up? I can understand on higher hp trucks needing it just seeing if its needed in this case, or if just installing the new valve will be ok. Thanks...
