Question about LML
Don Alonzo
Mar 5, 2022
5
Hi everyone. I have a 2015 GMC 3500 deleted without any added power. I do have a lift pump and cold air intake, but no other mods. I was pulling my RV and had a strong vibration, tons of white smoke and moderate power loss. There was lots of oil on the engine and now have blow by in the oil filler. See attached video. Any suggestions? IMG_1322.JPGIMG_1325.JPG
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,201
363
At Da Beach
Sounds like you cracked a piston. Why is your fuel filter on the drivers side of the motor? Did the truck have twins on it at one time?
2,145
interesting filter location. I kinda like it. seems much easier to get to
and I agree, sounds like a cracked piston
Nate’s Dmax
201
47
Sorry to say it but your engine is toast like the others said. Rebuild or another engine will be required. Most likely an injector stuck.
2,145
time to put a boroscope down the injector holes. or just pull the heads. I'd start looking around your area for a used engine you can swap it out with. probably easier then rebuilding yours
