Question about lift pumps
dunnc1991
101
Winchester, VA
I've searched around and had a question on lift pumps. Coming from the powerstroke world, talking abou TV running an airdog/Fass is like talking about the anti christ. Everyone has horror stories of them constantly failing and motors burning up. Not sure if this is from the earlier models or not. Planning on buying an AD ll 4g in the next few weeks, but just want to be sure I'm spending my money well and wondering why no one runs an aeromotive or fuel lab type pump like I'm used to seeing. If anyone's got a thread they can point me to I'd appreciate it.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Nothing wrong with the aeromotive or fuel lab, just most like the all in one design, and lower price. The powerstroke is a bit harder on pumps as they run a good bit higher fuel pressure than a duramax can handle stock.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
From my experience when i worked for XDP slinging parts it mostly comes down to price and installation. FASS/Airdog (165GPH)are similarly priced with FASS being cheaper but what i found is that a lot of people dont want to deal with the installation of the fass which includes dropping the tank to install their draw straw so they will pay a tad more for the airdog. then again there are plenty of other pumps that dont require a draw straw.
The bigger suction tube is a beneifit for the pumps that include it but in my opinion not necessary unless you're going with big fuel upgrades.
i personally run a Airdog2 165 (insane deal) but if it was up to me id run a Fuelab 200 pump. its a superior pump in every way, but i will set you back about 150 more than a similar product from FASS/Airdog.
and as far as longevity ....they all have failures so pick your poison
doug9940
Ca LLY
Dec 6, 2009
391
56
Corona, Ca.
Aeromotive just displayed their new diesel pump with air seperator and filers at SEMA. It is similar to an AIRDOG or FASS. I saw a short video of it on Diesel Army Magazine's website.
Big Chris
2 Duramaxes> 1 Duramax
Mar 30, 2010
361
46
Rives Junction MI
I've had Kennedy twin pumps on my lly since 2008 and have had no issues. Almost 200k miles on the pumps. I've had them on my lmm since 2012 and no issues as well. About 50 k on them.
doug9940
Ca LLY
Dec 6, 2009
391
56
Corona, Ca.
for a price tag over $1000 it better do more than pump fuel
Their 01-10 Duramax Diesel Retrofit kit lists at $1,385.45.
Their 01-10 Chevy Duramax Diesel Lift Pump kit lists at $1,827.96. :eek:
And I thought FASS was expensive. I'll just stick with my AIRDOG 1. :thumb:
bcdeutsch731
619
13
41
Illinois
I run one AirDog 4G on my race truck with no problems. My race truck has twin LBZ pumps and 175% injectors.
I also run a 4G on my 2015 with no problems. They are great pumps and easy to install.
550
I got less then $300.00 in my setup, sister diesel adatper for 1-14" thread a wix universal 1-14" filter head, and Jegs 130gph fuel pump and some fittings... Definitely not "plug n play" though..
Resently added Some -8 braided lines and -6 for return lines(sitting on shelf) to replace the steel ones that have been bent
Bikey
Corvette Racer
Mar 18, 2013
17
Brooklyn
I have an ADII-100. Works well, no complaints. I ditched their filters - the water separator filter is junk, the other one is nothing special. Here is my filter setup:
water separator - Baldwin BF1275
main filter - Donaldson P551315
(both simply screw on to ADII unit)
in place of OEM filter - with a Nicktane adapter, Donaldson P551311 (this filter is long - I increased the size of the spacer to keep the filter away from the exhaust manifold; can also use P551313, which is shorter)
