The lly engine harness I have needs some attention in relooming and taping. Where can I get some stuff that is close to or better than factory looming and tape?
Make sure you use the hi temp loom, I found out the hard way that all wire loom is not equal. Also, try to use the non-adhesive tape, the adhesive backed stuff gets all gummy, slides around and makes a mess if you ever have to unwrap it to add wires or fix problems. http://www.summitracing.com/search/...ng/part-type/convoluted-tubing-and-wire-looms
James, I have a bunch (like a ton) of loom, I'm assuming it's around 1-1.5" loom so it's decent size. If you want you can have it!
James, I can throw some tape and loom in with your harness when I ship it back. Should have it on the way back to you monday or tuesday. :thumb:
Ben
I would very much appreciate that ben! Thank you!
I have to fix a bunch on that LBZ as well. If you end up needing more, we could go halfsies on a bulk box. I probably need a little .250 and .500 to fix everything here. Pretty much all the SLT is crumbled, but the main harness tape is looking good.
