Thought the thread I read in here said there was a 10 mm hex nut on the oil filter housing.
I got under the truck, saw the hex nut plug and took it out from the bottom. Then when I was dropping the sensor line down I saw another hex nut on the side.
The one I pulled was an 8 mm on the bottom. The one on the side is 10mm. Does it matter which hole it goes in?
I'll just sit here nursing a beer for a while
