I have read a lot about pump rub kits or wear plates. I have a 2007 GMC 2500 classic. Should i be concerned about this? Does it affect all years?
Thanks in advance
Thanks in advance
Since you said you needed a rear seal and bushing,did you run the t case out of fluid? Alot of times when you need bushing you may need rear bearing and maybe more . Check your front yoke for groves also.How many miles on truck, is it one or two piece drive shaft?
