pump rub kit?
02ilduramax
632
3
fulton,illinois
not sure but would this have anything to do with my transfer case not having fluid in it i bought it while i was in afghanistan and i still am dad went up and test drove it and everything was fine and the dealship said they changed all the fluids and about 2 weeks ago dad used it at our farm and went to use 4wd and its made a weird noise so he broght it to a chevy dealership closer to where i live and there was no fluid
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
If your going to be running it hard i would,i had 2 spare cases and between my truck and my parents work truck the pump ate the case on these.I bought some cheap 1s from Idaho transmission warehouse
JMAZ268 had a really nice 1 that he got from merchant but it required use to take it apart a little more.The 1 in my truck only made noise in 4 wd also. id start looking for a good transfer case to swap out its easy to do, but before you reinstall buy a set of trans snap ring pliers as you cant split the cases and install the pump rub fix so this doesnt happen again.Good luck
dieselboy04'
DieselBoy04'
Mar 23, 2008
135
Virginia
Do a search on you tube. "Merchant Automotive pump rub upgrade Truck U" should give you a good idea what needs to be done and why. Full instructions are on merchants website in the lower left hand corner. I just did mine and considering the kit is 99 bucks and a new transfer is a lot more. I did the upgrade and just in time too.
SmokeShow
6,818
Lawrenceburg, KY
Put a kit in the new case...
Merchants kit is really nice. There are cheaper options that work just as good. ;) I think Tony Burkhardt (All Season) sells both kits. Take your pick. :D
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
nothing too special....simple and easy. I swapped the seal that the driveshaft yoke slides into at the same time...
Mine had been leaking a slight amount awhile back and think it was getting some water in the transfer case, cause fluid was pretty milky when I drained it.
