Having an issue. My truck is pulsing at an idle. everyone said it was my fpr. So i Took it to a diesel shop. They replaced the fpr , fuel filter, and its still doing it. They hooked it up to the computer, tested the injectors, good, tested the vacuum on the pump, good, but it shows that at an idle my rail pressure should be at 5000psi. It's jumping around any were between 4700 and 5200. Could it be a bad one right out of the box? Or is there something else I could look at? The problem is I will have to pay for labor again to reinstall a new one but the fpr I can return to the dealership. The weird part is that it only does it in drive at an idle. If I put it in neutral it goes away. And while I'm driving its fine and has good pressure. 02 2500 lb7
