Pulling truck pics
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Here's some pictures of my truck and all the extras for pulling so you guys can see what I've done to it.
traction bars.
drive shaft loops front and rear.
rear
front
front with bracket
bump stops
reinforced hitch
hitch with sled stops attached
Truck with weight bracket and hitch setup installed.
New stack!
Disclaimer: "Balls Deep Diesel Performance" is not an real operating diesel shop. It's just a joke between me and a few friends to get back at all the ridiculous diesel shops in our area.
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Sikdmax thats funny!!!
Kat i dont run those tires when racing. They are 35" tall and really heavy. I have a set of weld racing rims and toyo A/T's that i drag race with.
Travis the rims you see are mickey thompson classic 2's that have been powder coated.
Thanks a lot guys and gals for all the complaments.... It means a lot to me that other people can appriciate the same kind of things that I do!!!
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Looks Good
Eric, I need you to take some pictures for me. I want mine to look that good! I tryed to take some pictures of the hitch set-up but my camera is a old sony and it takes floppy's. I tryed to down load them and had problems. I will try to get some to show. P.S. Eric there is a pull in 1 month in KY! I think i'm going to go. I need a tune-up before the OBX race/pull. Will there be any of the Sunshine state guys at the OBX event? Thanks Jeff
SmokeShow
6,818
Lawrenceburg, KY
Eric, I've always loved the way your truck looks. Just looks like a bad ass.
Which pull in KY are y'all coming to? Sturgis, KY? TS - Bowling Green, KY? T-N-T in Stanford, KY?
Just wondering. :D
C-ya
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Alittle info for people wondering about the size of the U joint shields.
The back shields are 7.5 inches inside diameter. They measure 1/4 inch thick. And are 6 inches long. I have the big aluminum drive shaft so the pipe had to be BIG.
The two front U joint shields are 4.5 inches and are 1/4 inch think. They are also 6 inches long.
The traction bars are 2.5 by 2.5 sqaure tubing that is 3/16 thick. They are 7.5 feet long (which i think are about a foot to long) And have tractor top links on each ends so they are adjustable.
