Pulling tips
J17HENRY
May 23, 2009
52
alabama
I have pulled several times at our local fair with good success with my old 01 550 hp truck. I have bought another truck that should b in the 800 hp range. I pulled in 4 lo 3rd gear before, Should I pull in 4 lo 4th gear with the hp I have now? We can't have hanging weight street legal trucks. Any other mods I should do? Any input would be great as I Know very little about pulling.
bluecollar
351
ia
with that hp 4th would be worth a try.. 2nd gear start as well should work good with the twins. but is a lil hard on the converter if you sit to long.
bluecollar
351
ia
I have made a tune but not tried it yet.. so maybe someone can chime in for exact tables.. I changed 1-2 all tables BUT A NORMAL MODE to 0
whytry
Oct 11, 2010
282
every pattern but A set to 0 D5000 D5005 D5020 D5025 D5035
bluecollar
351
ia
:thumb: I did that from one of your other post. now will that only work with the gear selector in D since I still run third and is this possible for a lmm do you know.
whytry
Oct 11, 2010
282
Yes will work on lmm it will start in 2nd unless you are in normal mode anything else will start in 2nd
whytry
Oct 11, 2010
282
On lmm put your gear selector in M tow haul and select 3rd gear it will not shift above 3rd
Lb7 heaven
Delete it
Mar 26, 2011
12
What gears do you have? If you have the stock 3.73s I don't think you'll be able to hang 4th gear efficiently.
