hey everyone, been quite a while since on here. still got truck which has been fine till now. love the truck and gonna keep it. its a 2001 lb7 with 150,000 miles only mods were 4" exhaust and PPE programmer run on lowest tune sometimes. otherwise stock truck.
the injectors were replaced about 35,000 miles ago with factory remanufactured bosch from dealer. now it has started a slight miss at just off idle (just move the foot feed throttle) just enough to like moving the throttle off the stop, and no rpm increase, and engine starts running and idling ruffer. the fuel milage has also dropped. it also begins to smokes when started below 40 degrees and really rough idle and gets worse the colder it gets. no smoke after warms up or during summer, just the rough idle and low fuel milage.
what I'm asking is how hard is it to loosen each manifold and move or gently pry away from the head to see which cylinder or cylinders are smoking when cold? i think i have a cracked injector body or bad injector. anyone have an idea how to do this the easiest way either one side at a time or both if easier. I'm hoping this would save some money on only replacing the one bad injector since all have low milage.
if done in summer, i would have to ice the engine compartment down with bags if iced down overnight to see smoke coming from bad cylinder.
any help would be appreciated! thanks rob
