PT cruiser
2,137
Been working on my brothers car for the last few days. It over heated and poped a head gasket and wouldn't run after that.
Got the head off yesterday. He is going to bring it to a shop to see if it is salvageable. Also we are going to replace the radiator and timing belt while we are in there.
For how cramped it is in the engine bay it is not really that hard to work on. Had a tougher time on my truck for some things. The only real bit¢h is the engine mount bracket. You have to lift the engine up like 5 or 6 inches just to get enough clearance and it still has a hard time coming out. Not looking forward to putting it back in
Anyone else ever work on one of these turboed PT cruisers?
2,137
Got the refurbished head installed and torqued down. New timing belt kit put in with new water pump, idler and tensioner. Set the timing, etc. Plus a bunch of small things and other brackets, exhaust, heat shields, etc
Few more hours tomorrow we should have it almost complete. Going to drop the pan and clean it out but with the rain we've been having it may have to wait a few days. Would like to roll it outside to pressure wash the underside before pulling it apart and I'm not going to do that in my garage
2,137
Got the car running the other day. Fired up on first try
Pulled the oil pan and cleaned it up. Some sludge but not too bad with the coolant and oil mix
Have fresh oil in it and plan on running about a week and doing another oil change
Little bit of smoke for the first few miles burning off the oil in the cylinder and anywhere else it got during disassembly and putting it back together. But cleared up after a short drive.
Seems to have a little bit more power and run a little smoothly :thumb:
3,727
296
They're not a bad car if you can get past the styling. Don't really have anything useful to add, just wanted to say I'd been following along. Always nice to see progress on projects, even the occasional gasser.
