PS Lines and Box Replacement
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Steering box is leaking, so thats gotta be replaced, gonna grab a local parts store reman.
The PS lines looked lousy when I did the pitman arm so might as well repalce them while I am removing the box.
MA?
https://www.merchant-automotive.com/p-5423-power-steering-line-kit-lb7-lly-lbz-lmm-2001-2010.aspx
Or these guys
https://www.strictlydiesel.com/p-3323-driven-diesel-power-steering-lines.aspx
Alligator
https://www.alligatorperformance.co...d=CISe_pCa58wCFQxahgodXgQD4w#customer-reviews
Thoughts?
ScreaminDuramax
Sep 19, 2013
345
Torrance
the MA and strictly diesel is the same Kit. Not sure on the Alligator ones, the pic looks like it uses the factory hard lines, splice and flare both ends and then use the braided section to replace the leaky hydraulic lines
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Or just ACdelco replacements, which comes to about a third of the price....
Harbin_22
3,858
Southern Indiana
I have the strictly lines. They are nice for sure. Fit well, had all the necessary brackets, etc. Little pricey but I do like the hydro line over braided, should last forever. DHD actually says you get some pump noise through the braided line vs no pump noise with hydro line.
minerigger
2,660
Casper, WY
Could you pull the stock lines and go have a hydraulic shop make you good lines to replace the crappy stock rubber portion
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,198
362
At Da Beach
Thats what I do. Just make sure they clock them properly and use smooth crimps. Dont let them talk you into swivels, they are expensive and just make their job easier. I use braided stainless steel on mine.
Its not the rubber thst fails, its the bubble crimps they use on the connection between the hard and soft portion.
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
I would love to, but I don't know any shops local to do it and I can't afford the down time. Truck is my DD
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
I had to lengthen mine due to my hotpipe rubbing on the line at the hydraboost. I bought a used JIC flare tool from Ebay and flared mine and then bought the hose loose, mocked it up, cut and then brought them back to have crimped. The line at the pump I had to have welded on as there was no room used the flare tool. Going to do the same thing with the transmission lines...
Fortunate for me I have a hydraulic hose shop about 5-10 minutes from me, may want to check some NAPA stores can repair hoses.
http://www.dieselplace.com/forum/3231618-post141.html
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
In an effort to maintain the OE aspect to the truck and not deal with aftermarket stuff, I ordered AC Delco lines, and a reman pump from Rock Auto. While I miss getting fancy stuff, the wallet does not :)
Mike, I will try and be gentle when removing the old lines, with any luck they will be out this week. I will keep you posted.
minerigger
2,660
Casper, WY
I wish I could have learned that 3 yrs ago. I'd be so rich it wouldn't be funny
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Nothing on power steering system has been changed that a stock line will not fit with a little manipulation/bending of the hardline. Any and all modifications I do are with the intent of easily being reversed back to stock with little effort. Open the hood and it looks like a stock engine that has a sock on the hot pipe, kinda sleepy looking and I spend only a little at time
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Like I said, if I had a local hydraulic shop I trusted and had some down time to run back & forth, I would def do that option.
Maybe when I replace the hydroboost I will redo the lines. :rofl:
