Promise i'm not a liar
Lance LB7
Nov 5, 2013
Kentucky
I know its hard to believe anyone on fuel mileage but these numbers are hand calculated and I wanna see if anyone else has ever seen these. filled up at home and drove to college, all highway and interstate. filled back up, 70 miles, and averaged 29.2 MPG. anyone else ever seen anything this high or is it a fluke? single cab zf6
jacobdewey
This won't last long...
Jan 14, 2011
972
I averaged 25.xx one day while hunting. I spent alot of the time driving 55 mph or slower. My guess is you had a nice tailwind.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Ive seen 23 from mine when i had it. at only 70 miles though it would be easy to not being sitting as level as you were when you filled it up the first time and having the pump click off early and even a half gallon descrepnecy would throw that short of a MPG calc off alot. see what I'm saying is a 1/4 of a gallon would make a 3.1 mpg difference. a half a gallon would make a 7 mpg difference. hard to get a accurate reading off a 70 mile run. when i was checking mine years ago i would fill up to the cap or there abouts so as to fill up to the exact same spot everytime to get a really acurate calculations.
Lance LB7
Nov 5, 2013
Kentucky
Yeah I get what you're saying catman. I got 28.5 one other time and let the pump run again and still showed 24.7. on that drive the truck usually averages 24-25 and I just wanted to see what was the very best I could get. True aberage with idling and everything else is about 19. Seems to get the very best mileage right at 70
PACougar
2,105
41
El Dorado Hills, Ca
Do you fill up until it clicks or until the filler neck is totally full and you can see the fuel sitting level in the neck? If you simply fill until it clicks and you only drove 70 miles, you have a pretty bad sample that I wouldn't count as remotely accurate.
Dirtymaxx03
3,109
one thing you need to check is your tire size calibration and make sure your truck isnt recording some extra miles that the tires arent turning. double check that and see if 29mpg still happens. if it does, you have a one of a kind dmax.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Yup,You could be off up t a few gallons which pooches the mileage/gallon accuracy. Need to fill up till you see it in the neck each time for accuracy!
NinjaMax
WTF!
Oct 3, 2012
1,266
42
Severance, Colorado
what is the normal tank size on a 2500? this morning I ran mine to 3% and it took a little over 21 gal? then after it was full (to the click) my cs was saying 96% full. I always thought it was a 24 gal tank?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
26 gallon for 2001-2010 short bed trucks.
I think GM lied to me though. Ive run my truck out of fuel a dozen times or so and never in 240k miles put more than 23 gallons in.
Yet some people claim they have put 25-26 gallons in their 26 gallon tank...so who knows. :rolleyes:
Lance LB7
Nov 5, 2013
Kentucky
Yeah I fill it up to the click so it's probably a little off. But I'm sure on the mileage I've googled it before. But like I said I clicked it and let it run again and it showed about 25. I think that might be a truer number
catman3126
Jul 24, 2012
2,636
NE Oregon
Ive put 22.5-23 in my LLy ccsb several times as soon as the low fuel light comes on and I have driver 40 miles or so with the low fuel light on so im sure mine must be pretty close to 26.
Awenta
4,090
CT
Maybe you have three gallons of crap in your tank :D
I've gotten 25 and change in. I'll find the receipt for you!
5,808
Maybe Ben's going to some very generous gas stations. :roflmao:
I seem to find the opposite. my 34 gallon tank has taken 35 gallons a couple times. that was everything the tank had to get me to the fuel station (surging and lift pump was making all kinds of noise). Soon as my light comes on, i have 5 gallons left in the tank. i use it as a "reserve" like on a quad or motorcycle lol
Dirtymaxx03
3,109
Does anyone elses low fuel light kick on right about the time their truck runs out of fuel? My low fuel light is a bit retarded
LbZzF6RCLB
Feb 4, 2015
Butler Pa
I get high mileage My self. The zf6 and reg cab plays a big part in it. Like the truck by btw:thumb:
