Project Mordor - '67 Chevelle AWD/LBZ Repower
Liquid_Beaver
Aug 20, 2013
13
Colorada, USA
Hello everyone!
I haven't posted about my car in a long time because I have been looking for a new place to keep it. It's been more than an hour away at my brother's house, so I can only get up there twice a month, and needless to say progress has been going way too slowly.
Over the weekend I was given the amazing opportunity to move into The Race Cave in Denver, which is owned by Dave Balingit, the regional director of the National Auto Sport Association. This shop gives me access to two lifts, all the single-use tools that I no longer need to invest in, as well as many, many years of knowledge and expertise from the racers and builders. On top of all of that, the shop is less than 15 minutes from my house.
http://imgur.com/IeVeV8N
I was also able to finalize the build for the AWD, thanks to a guy from France I only know as Alex.
Now, onto the build!
I will be taking this car... http://i.imgur.com/xtTPrlr.jpg
...A 1967 Chevelle Malibu 4-Door (originally gold on gold) and turning it into my dream car that I have been planning for going on 8 years now. The drivetrain will be a 2006-2007 LBZ mated to the Allison (or a 4L80E if that is too big), and a NV149 transfer case out of a Denali for AWD.
The first few steps, that will also take the most time, are:
  • Strip the car and clean every reused part (I hate working with dirty parts).
  • Take the body off the frame. Box the center section of the frame and reinforce everything.
  • Design and install custom roll cage. I will be attempting (if safe) a double hoop in the roof, so the rear is a relative mirror of the front. It is very, very important to me to retain seating in the rear. Both bench seats will be removed because of safety. I'll be sad to see them go as I've never had this unique of a driving experience of a car in my life. Plan is to replace both benches with 4 racing seats, a Recaro Sportser CS for me, and Corbeau Evolutions for everyone else. I plan to install and extend a center console all the way to the rear to hopefully make it look better. 3 point Schroth racing harnesses throughout, but provisions for 4+ point in the future if I want. Roll cage (and frame) will be painted or powdercoated fluorescent green.
  • Minitub if needed.
  • I would like to get ~275/xx/18's or larger all the way around. I am going for a square setup for the AWD, but with the added benefit of better rotations, and it limits further contribution to understeer,
  • Smooth the fire wall and recess 6" to 1'. A Duramax is the same depth and width as a big block Chevy, it is just taller because of both the depth of the oil pans and the amount of accessories on top. I want to clear up more space in the front because it is going to be really tight with all the coolers, radiators, and front diff. up there, so I plan on having to notch back the center section of the fire wall quite a bit. It will allow me to both center the weight in the car better, as well as lower the engine down because of extra oil pan clearance.
  • Custom floor pan grid and flat floor pans. I need to get as much ground clearance and head clearance as possible. Currently the bench seats both sit on platforms, and there are all kinds of other high and low spots in the floor pan. I have to cut so much out to fit the new tunnel and get clearance for the front drive shaft that it makes more sense to just build the floor to exactly what I need. I will be welding in a grid of square tubing to support 14 gauge floor pan plates. The plates themselves will be sealed and HD riveted to the grid, and the transmission tunnel will be removable.
  • Skid plates for the front half of the car, and one for the diff.
  • New suspension. I am leaning towards air bags, but I am still able to be swayed if a different setup wins over performance-wise. New upper and lower front control arms will be absolutely necessary, and I may be "remote" mounting the shocks because of clearance issues. Spindles will be out of the donor truck.
  • Rear end from the donor truck will be trimmed down to fit the car. Gearing will probably be very high, so 2.xx's. Front diff has to match it.
  • Install new InfinityBox wiring system. These things, while expensive, are so damn cool and will really clear up a lot of headaches later. Not to mention they are incredible capable wiring systems. http://infinitybox.com/
  • Dakota Digital VHX gauge cluster. The only extra gauges I will need will be boost, transmission temp, and pyrometer. It's possible to have the display on the cluster show these, but I would have to push a button to scroll through each of them, they don't have a dedicated gauge. http://www.dakotadigital.com/index.c...rod/prd798.htm
  • Reuse truck radiator/intercooler, or do split radiators if it improves space. Mounting at an angle with electric motors is also an option.
  • Battery bank moved to rear.
  • ~40 gallon fuel cell in the trunk. The trunk on this thing is really, really massive, so there is plenty of room for a low and wide fuel cell that won't affect my ground clearance. Rough napkin math is you gain 3-5 MPG per every 1,000 lbs of weight you shed. The Chevelle is already 4,000 lbs lighter than the HD truck, minus how much weight I add beefing up the frame, adding the roll cage, etc.. Even conservatively at 2 MPG/1k lbs, I will be around 32 MPG. This doesn't take into account much lower rolling resistance, custom tunes, much better aerodynamics, etc. My goal is to break 40mpg (this type of project has already hit 36-38 really consistently), or hit the limit of the Duramax MPG, whichever comes first. I think 40+ is well within reach with an OD transmission.
  • Turbo inlet was originally going to be through one of the headlight openings like the Chevelle in the link below, but I like the look of 4 headlight too much to do that. I will instead find, or make, a scoop to pull from under the center section of the bumper, around where the hood latch is.
  • Exhaust routing TBD. It will be 4-5" from the collector back, so it may be routed through the crossmember. May end up double-mufflering it if it is a single outlet, depending on what it sounds like. Going with Magnaflows as I had them on my last Camaro and loved them. Quite a big difference than my multiple sets of Dronemasters.
  • New side mirrors? Side mirrors on this car were dealer added most of the time (including mine), so the variation in their placement is huge. I can't open my wing windows without swinging my side mirrors away first. Definitely going to fix that, but might go with a more modern mirror at the same time. Maybe something with signals?
  • Aftermarket A/C to replace stock A/C. This is both for more space in the engine bay, and modern controls (no cables/vacuum).
  • Interior will be predominantly gunmetal gray with black accents.
Other than small custom details here and there, that is the bulk of the project.
As of right now, I have taken 4 rolling chassis and turned them into street legal, moderately powerful (most horsepower was 425/450 ftlbs), muscle cars. For the last 8 years I have wanted to build my dream car, and each time I went through the options, I kept coming back to diesel. I wanted uniqueness, difficulty, MPG, power (360hp/650ftlbs stock plus a mild tune will be outrageous in a 3k lb car.), and it is a project that I will get to complete with my brothers and Dad, maybe the last one we get to do together. I have no concern for resell value, if I did I would have gotten a 2 door. I've had coupes, and for this, I wanted something I could actually bring people along in.
Thanks for reading everyone, and I look forward to keeping you all irregularly updated!
Liquid_Beaver
Aug 20, 2013
13
Colorada, USA
Mini update carried over from the old thread:
I got the interior mostly stripped. All the original carpetting and seats were still in the car, but still looked fantastic for their age. I removed all the carpet, most of the tarpaper (little piece on the driver's side is really stuck on there), all the matting, and cleaned it all up. As you can see, the floorpans look amazing. The orange color in the second picture is a metal protectant that was sprayed on before the car was painted. The only rust is a tiny bit of surface rust under the wire ribbon on the driver's side, most likely from wet floormats.
My dog was very mad for taking her favorite seat out of the car. This is the only car she has ever been able to get in on her own, so she loves to go for rides in it.
Well here are the first official teardown pictures!
http://i.imgur.com/0rqCqaR.jpg
http://i.imgur.com/ZqHIvQ0.jpg
Now that I am in the shop with space and good lighting I will be documenting everything once the more boring stuff is out of the way.
Liquid_Beaver
Aug 20, 2013
13
Colorada, USA
Hey everyone! It's been a while, so I figured I would give you all an update.
The Chevelle is now completely stripped of everything except windshield and rear window. Here in the next two weeks I hope to start getting it sodablasted, which I may just end up doing myself so I don't have to keep sending things out.
I finalized the design on my "engine cradle". I am removing the stock K-member for clearance, but I have to put something back in order to retain strength in the frame. This cradle will actually serve quadruple duty. It replaces the K-member (and is much stronger), it will be the main mounting point for the front differential, it will be where the lower control arms mount, and it will serve as a skidplate. The frontmost green framerail is also new, as those two corners of the stock frame (in white) do not connect. The red plane is roughly where the firewall is.
The cradle will be the same height as the rest of the frame, and will be tapered at the front. This should not effect my angle of approach when pulling up inclines, and will not effect my clearance.
The last picture shows roughly the location of the crankshaft pulley. It will sit just behind the centerline of the wheels, which is where the front diff. and CVD's will need the most clearance. The wheel/tires in the model are a 275/40/18 on a 18x9.5" wheel. I will have this size wheel and tire combo on each corner, with the same backspacing if at all possible. I decided on a BF Goodrich G-Force COMP 2 A/S. I had the KDW NT's on my last Camaro and loved them, and these are supposed to be a significant improvement. I haven't decided on wheels, but I am really leaning towards an Artillery wheel.
http://farm4.static.flickr.com/3031/2689299235_bbb889c89e.jpg?v=0
As the body is getting sodablasted I will be stitch welding all the seams on the frame, and enclosing all the C-channel areas. I will probably ending up painting the frame as opposed to powdercoating so that I can still make modifications to it later, which will probably happen a lot with this car.
I've been planning this car for 8 or 9 years now, and while I am so excited to finally be working on it, the waiting for parts and slow progress is killing me. I know if I rush I am going to be really unhappy, so doing it right will take a bunch of patience. I hope I have less than a year left, but we will see. I think once it starts to come back together, it will be a lot easier to get help with problems, because right now most people just see a stripped body.
3,729
297
Wow, how did I miss this thread until now? This is a cool project!
I don't know much about the older GM cars, so I can't really offer any useful contributions to the discussion, but I will sit here and drool over the photos and progress reports!
