LB7: Procedure for adjusting valvelash and specs
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Could someone give me the procedure for adjusting valve lash and the specs for it.
Waid
S Phinney
4,008
Quncy, Fl
There are a few techniques. It depends on camshaft selection if you can do the OEM recommended way. I never do it that way just to make sure the lash is adjusted correctly anyway. I prefer opening one valve on that cylinder that is being adjusted to near full open and adjust the closed valve. I usually do .011 on intake and .012 on exhaust. I have done .010 on intake as well. I think factory specs are .012 on intake and .013 on exhaust.
