I have a 2008 Silverado 2500HD Crew Cab (LMM) with ~145k miles. Truck is all stock with 2 batteries and 2 alternators and I’ve had zero issues prior to this. I had a parasitic drain on the batteries that would periodically draw the batteries down, but never low enough to affect starting. The first indication of a low battery was the dual climate control would reset to 74/74. Recently the truck sat about a week and finally went low enough to not crank. I jump started at the passenger side battery and the truck started and runs fine. However, since that jump start, or maybe since the batteries went dead, I have the following 4 conditions, and no codes stored.
- Service 4 wheel drive in DIC
- Service Trailer Brake system in DIC
- ABS and Emergency brake lights on
- Park Assist System Off
- Disconnected both batteries for 1+ hour
- Checked all fuses in cab and engine compartment using a continuity tester
- Checked TREC fuse and removed/replaced it while key is on (Click sound when replacing it)
- Attempted TCCM re-learn multiple times with no success. No sound, movement or shift occurs
- Replaced both batteries with new identical H6 batteries
