I need to know if anyone here can point me in the right direction in figureing out a major issue i am having after redoing my motor for blown head gaskets.
I will start with some info about the motor,I bought this truck for a really good price and it did not run, original owner says it did but i never got it to start when i went to buy it.Anyways i was told his son drove around with the truck for a while with blown head gaskets so after i bought it I tore it down to replace the head gaskets ck the heads take a peek at the bottom end. The machine shop i took the heads to had to do alot of work to get them usable again be recessing the valves and replacing 4 valves them cutting them down so they were flat.
OK,
So now we are here to present day and the truck will start but,,, i have had to relace 6 injectors and all the balance rates are looking real good with my scanner but when i give it any pedal it sounds like the rods,pistons or whatever can bang loud is going to explode through engine wall. I know that injectors will give out a fuel knock but this sounds really intence and again the balance rates are real good. I just pulled the glow plugs and turned the motor over and it seems either the injectors are firing fuel or leaking fuel but the cylinders are not dry. I was also told that you may have to program the injectors to the firing order of the PCM or something of this sort. I am really at a stand still and need this truck on the road,so i would like to know if there is any forum members here that could possibly put me on the right track to getting this fixed. I am not sure if any of this is making sence so if any other info may be needed in order to help out please tell me and i will answer any questions that will lead me to the fixing of this truck. Thanks in advance Bill
OK,
