Price Tag
rshunter
Aug 14, 2018
20
Roughly how much would this list total up to in your opinion? Thanks for the input.
- Stage 5 Suncoast allison 6speed trans rebuild with alto clutches and triple disc billet converter
- New transcooler
- Fleece performance Trans Cooler Lines
- Transfer case rebuilt with pump rub elimination kit
- PPE Transfer case Brace
-New water pump and ALL related coolant hoses
- New Idler pullies and new serpentine belt
-New Radiator
-New all aluminum intercooler
- 42% over CP3 injection pump
- New front wheel bearings,
- New CV shafts
- Moog upper control arms and ball joints
- Moog lower ball joints
- PCV reroute
- AFE heavy duty diff cover
- Tri Fold Tonneau cover
items prior to Feb 2018:
- Air Dog 150 Lift Pump
- Moog tie rod ends, idler arm and pitman arm
- EGR delete
- PPE downpipe
- MBRP 4" straight pipe exhaust
- PPE fuel rail valve
- replaced all shocks 20k miles ago
- Carrier bearing for driveshaft
2,207
10,000 Bob. I bid 10,000
$10k? You can have it. $10k would put me in the red. I think it would be at least a few more then that.
Does any of this include labor for installation or is it just parts?
CentolaCCSB
It will probably break
Nov 2, 2015
322
Mass
How handy are you? I mean CVs, diff cover toneau cover, wheel bearings and upper control arms are all pretty easy to do if you youtube a few videos. Most if not all that can be done in a driveway with a jack, jack stands and some air tools if you have access to some. Might be able to save a few bucks doing that stuff yourself. Just a thought
rshunter
Aug 14, 2018
20
These are items listed on a 06 Silverado 3500 I found for sale. Just trying to do the math in my head. Thanks
1,941
What are they asking for the truck? That would really kind of help here......
1,941
Thats a decent price. Mods dont add dollar-for-dollar value to a truck. In fact, some mods can actually detract from a truck's value.
rshunter
Aug 14, 2018
20
The problem is Carfax shows the truck had 1000 more miles on it 3.5 years ago then the seller says it has. New instrument cluster ? IDK
2,207
I ran a history report on my LB7 before selling it because a potential buyer wanted to see one. The report estimated the milage based on the last record and guessed at the miles per year. It was high too.
I wouldn't sweat 1k mile difference. If its not stolen or had any major damage not fixed by insurance then it wouldn't bother me
If I'm not mistaken there is a sticky here, a member can run you a history report that you can compare to your carfax
rshunter
Aug 14, 2018
20
I see how what I said was misleading. The vehicle allegedly has 168K right now. Carfax says it had 169K back in 2015. There's most likely a few more miles on it since then. Especially since the current owner advised it has made trips to Utah from NC this year. Just doesn't add up. I guess it is what it is.
